EtherOAM.FndVLANFail
Description
Any event from a VLAN will pass the VLAN name as an index to find the VLAN object. This error indicates it is not possible to find the VLAN object from the input index VLAN. This should notr occur because VLAN objects are maintained by the VLAN module (client) and an invalid VLAN is filtered in the VLAN module itself.
Remedy
Check that the specified VLAN is present (valid VLAN) in the system. Whether present or not, there is a possibility of memory corruption in the VLAN module/message exchange. No user remedy is available other than dot1ag process/system restart.
Severity
Error
Message Text
Not able to find vlan %vlanName%
Message Parameters
Name Type
vlanName String
Applicable Platforms
